Re:[SOLVED]Templates customization (1 viewing)
TOPIC: Re:[SOLVED]Templates customization
#3672
Cobessi Philippe
Re:Templates customization Karma: 0
Got it !
It works fine
Many thanks
You can close the ticket
Rgds
Phil
#3674
Re:Templates customization Karma: 84
Closed
All the best to Paris!
Rgds
#3681
Cobessi Philippe
Re:[SOLVED]Templates customization Karma: 0
I'm back again, sorry
In fact, i'mstill having a black background
What i dont understand is why you got a colored one and I, a black one on my browser
And the module shows now a unique column
So , i'm realy confused with configuration of component and module ( i'm not so clever in english..)
Though, would you kind enough to look at my Jsitemap config and modify what is to modify ?
I'll send you by private mail an access to the admin part of the site
Thanks for all help
Rgds
Phil
#3682
Re:[SOLVED]Templates customization Karma: 84
Hi Phil,
it looks like you have changed to wrong code in the print.css file
Yesterday it was ok. Now it' wrong.
Now it's
.jmap_sitemap { background: -webkit-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: -o-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: -ms-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: linear-gradient(top, #4196C2 0%, #00405C 100%) !important; }
the correct is using CSS id selector:
#jmap_sitemap { background: -webkit-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: -o-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: -ms-linear-gradient(top, #4196C2 0%, #00405C 100%) !important; background: linear-gradient(top, #4196C2 0%, #00405C 100%) !important; }
If the sitemap shows 1 column it means that you have disabled the option 'Renders sitemap by column' It should be easy but i'm getting confused too by all messing up. Rgds John
