Virtuemart products not showing even with VM product wizard (1 viewing)
TOPIC: Virtuemart products not showing even with VM product wizard
#3926
KKUBE
Virtuemart products not showing even with VM product wizard Karma: 0
Good morning,
I do not understand why my VM product are not showing in my sitemap. I did use the WIZARD button for showing virtuemart products.
The line Virtuemart products appears in Data Sources and it is published but nothing is shown.
Can somebody explain me step by step how can I have ALL products shown in my sitemap ?
Tamera
#3928
Re:Virtuemart products not showing even with VM product wizard Karma: 84
#3935
KKUBE
Re:Virtuemart products not showing even with VM product wizard Karma: 0
Hello, I did give you an access to administration, please see your mails.
Thanks for your help.
#6507
Masterhomepage GmbH
I have the same problem. Is there a solution or can I send my logins as well?
#6508
most commonly the problem is due to a misconfiguration of the VM database table due to the wrong multilanguage naming.
If you know how to correct table names in the data source SQL query you can do it, otherwise contact me at my private email and send me backend credentials.
#6509
Masterhomepage GmbH
