Re:http / https problems (1 viewing)
TOPIC: Re:http / https problems
#4022
zelena
[SOLVED]http / https problems Karma: 0
I'm having trouble generating a sitemap with all urls as non-ssl (http not https).
I currently use a plug-in on my site to force URLs as non-SSL (because so many errors appear if I use SSL).
In the back end, even if I log in as administrator in a non-SSL URL, the sitemap is produced as all https - which throws all kinds of errors in the SEO spider and "analyse sitemap links" as all pages appear as 301 redirects.
Is there a way to fix this?
Thanks!
#4023
Re:http / https problems Karma: 84
Hi, i think so should be easy to fix.
Despite your weird configuration ( by the way you should disable the https protocol at server level if you don't use it)
you can set a specific domain for links included in the sitemap. See the below parameter, of course you will set your non https domain.
#4024
zelena
Re:http / https problems Karma: 0
Thank you!
