Re:dont load jquery.treeview.js (1 viewing)
TOPIC: Re:dont load jquery.treeview.js
#4088
Erick Boileau
dont load jquery.treeview.js Karma: 0
I want a sitemap for users on my website but not with that expand-collapse tree view
just a normal UL > LI list
and I don't want to load jquery.treeview.js and no css at all, I shall do all myself
how can I avoid loading jquery.treeview.js and the script declaration
<script type="text/javascript"> var jmapExpandAllTree = 1; var jmapExpandLocation = 'location'; var jmapAnimated = 0;
I want only the RAW ul > li thank you
#4089
Re:dont load jquery.treeview.js Karma: 84
Hello Erick, the jquery.treeview.js file must always be loaded otherwise the sitemap wouldn't work.
But you can turn OFF styles to render it as a normal plain UL > LI so that you can use your own CSS.
See the parameter in the screenshot to disable the template. You can even turn on the 'Expand all' paramter to start the list all expanded by default.
#4090
Erick Boileau
Re:dont load jquery.treeview.js Karma: 0
all is already on NO but I definitively dont want any JS in my page that's too much and useless
if it is a static UL there is no needs for JS
i shall unload your treview js in another way but where can i remove the script declaration
thank you
#4091
If you like to get rid of every javascript do this in the source view file:
root/components/com_jmap/views/sitemap/view.html.php
Comment out the line:
//$document->addScript ( JURI::root(true) . '/components/com_jmap/js/jquery.treeview.js' );
and the code block:
/*$document->addScriptDeclaration(" var jmapExpandAllTree = " . $this->getModel ()->getState ( 'cparams' )->get('show_expanded', 0) . "; var jmapExpandLocation = '" . $this->getModel ()->getState ( 'cparams' )->get('expand_location', 'location') . "'; var jmapAnimated = " . $this->getModel ()->getState ( 'cparams' )->get('animated', 1) . "; var jmapAnimateSpeed = " . $this->getModel ()->getState ( 'cparams' )->get('animate_speed', 200) . "; var jmapDraggableSitemap = " . $draggableSitemap . "; var jmapLinkableCatsSources = {}; var jmapMergeMenuTree = {}; var jmapMergeAliasMenu = " . $this->mergeAliasMenu . "; var jmapExpandFirstLevel = " . $this->getModel ()->getState ( 'cparams' )->get('expand_first_level', 0) . "; jQuery(function($){ $('ul.jmap_filetree li a:empty').parent('li').css('display', 'none'); }); ");*/
#4092
Erick Boileau
Perfect ! it works as I want
it could be a very simple option in the config --> load JS : yes/no
thank you
