Re:caching (1 viewing)
TOPIC: Re:caching
#4166
Atlanta Internet Design
caching Karma: 1
In the settings/caching and splitting, the Cache standard, Precaching AJAX and Splitting of sitemap are all turned to off. Relative to seo should these be turned on and if so what would be the optimal setting?
thanks
#4167
Re:caching Karma: 84
Hi again,
those settings have no impact on seo.
The caching modes should be used only if needed when sitemaps are very large including thousands of links. In the PDF docs you find detailed instructions about these features, in your case you have a small sitemap so keep everything disabled.
Cheers
