Re:Match Xmap display and layout (1 viewing)
TOPIC: Re:Match Xmap display and layout
#4224
iMAGINE MEDIA DESIGNS
Match Xmap display and layout Karma: 0
I am using Xmap on my client's website, but I am trying to transition to using your sitemap extension instead. I have installed the extension and have the main menu and K2 items set as data sources, but I am needing to replicate what I currently have achieved with Xmap. You can see how it looks here: http://www.phoenixrentals.ca/site-map. How would I go about replicating this with JSitemap? This is what I currently have using JSitemap: http://www.phoenixrentals.ca/site-map-new. Any help is greatly appreciated. Thanks.
Mike
#4225
Re:Match Xmap display and layout Karma: 84
Hello Mike,
the main difference between the 2 layouts is that XMap is using multiple columns.
So the first thing to do with JSitemap too is enabling the ooption 'Render sitemap by columns'
After that probably there is some CSS styles to apply to have for example blue top element instead of black ones.
