Re:Exclude images from images site map (1 viewing)
TOPIC: Re:Exclude images from images site map
#4292
Roger
Exclude images from images site map Karma: 0
I'm using the Event Booking component for different events. Each event shows the main logo of the site, as well as a Facebook, Twitter and Google+ icon. I would like to exclude these from the site map. In the configuration settings under site map settings I entered the following in the exclude filters for images sitemap: img src='/images/logo.png', img src='/media/com_eventbooking/assets/images/socials/facebook.png' unfortunately there is no effect.
Is this the correct location to exclude it or should I do that in the event booking data source?
#4293
Re:Exclude images from images site map Karma: 84
Hello Roger,
you can use either the global configuration exclude filters or the single data source exclude filters.
But you need to enter only the name not the full path. For example: facebook.png, logo.png or simply facebook, logo
#4295
Roger
Re:Exclude images from images site map Karma: 0
Hi John
Thank you for the quick answer. This did it. How about auto generated images like thumb images like media/com_eventbooking/images/thumbs/1445170546_nhk.jpg? The name changes all the time, the number is added in front.
Can I somehow exclude an entire directory like images/thumbs?
Roger
#4297
It's the same concept. Each word in the path/subpath will be excluded.
Adding images/thumbs or simply 'thumbs' will exclude every image.
