Re:metainfo (1 viewing)
TOPIC: Re:metainfo
#4348
Atlanta Internet Design
metainfo Karma: 1
I have completely filled out both the Title for search engines and browsers and the Description for search engines for all pages, but when I check page source there is nothing. The Indexing directive is set to "use global". What have I done wrong?
Thanks,
Bob
#4349
Re:metainfo Karma: 84
Hi Bob,
i can't guess what's wrong but i can try.
1. Ensure that the plugin 'System Jsitemap utilities' is published
2. Ensure that domains used for metainfo is the same used to open and check pages. If you specify metainfo for http://www.atlantainternetdesign.com/ and open http://atlantainternetdesign.com/ without www prefix they won't apply, it's a different link
PS: your site http://www.atlantainternetdesign.com/ takes ages to open and shows badly at our end. Maybe it's important to let you know.
