Re:.htaccess changes per docs (1 viewing)
TOPIC: Re:.htaccess changes per docs
#435
Re:.htaccess changes per docs Karma: 84
Hi Bill,
the default syntax to rewrite sitemap.xml dummy file is this:
RewriteRule ^sitemap\.xml$ index.php?option=com_jmap&view=sitemap&format=xml [L]
RewriteRule ^sitemap\.images$ index.php?option=com_jmap&view=sitemap&format=images [L]
It normally works without issues, ensure you respect the exact syntax and spaces. The code you posted seems having not spaces after $ sign and xml suffix:
RewriteRule ^sitemap\.xml$index.php?option=com_jmap&view=sitemap&format=xml[L]
Best regards John
Bill Slaughter
thread linkthread link Re:.htaccess changes per docs
    emo
Bill Slaughter
thread linkthread linkthread link Re:.htaccess changes per docs
