Re:Search Engine Metainfo disappeared (1 viewing)
TOPIC: Re:Search Engine Metainfo disappeared
#4372
Giulia Giuseppina Bonaccorso
[SOLVED]Search Engine Metainfo disappeared Karma: 0
after i have configured my metainfo for all my page here:
index.php?option=com_jmap&task=metainfo.display&metainfojsclient=1
Today gives me all the boxes empty, like I did not enter anything.
But in the html page source you can see.
I need to edit my metainfo.
Please let me know
Best Regards
#4373
Re:Search Engine Metainfo disappeared Karma: 84
so it probably means that you are logging in backend with a different domain/www prefix. Metainfo are associated to each link, if links change metainfo change too.
If you specify metainfo for http://www.mysite.com/ and open http://mysite.com/ without www prefix they won't apply, it's a different link.
The same happens if you had links without SEF rewriting http://www.mysite.com/index.php/mypage.html and change them to http://www.mysite.com/mypage.html activating the Joomla SEF rewriting.
The same happens if you change links for https starting with http://www.mysite.com/index.php/mypage.html and change them to https://www.mysite.com/mypage.html
Every time a link changes the meta data associations is lost. Keep in mind that the URL is the unique identifier for meta data.
#4376
Re:Search Engine Metainfo disappeared Karma: 0
Yes,
this was the problem.
Many Thanks
