Re:Issue with JsiteMap (1 viewing)
TOPIC: Re:Issue with JsiteMap
#4428
Re:Issue with JsiteMap Karma: 84
Hi Ray, i hope you are well.
The problem is related to the server, it looks like the PHP Curl library is disabled.
Contact the hosting provider asking to enable it. In the meanwhile you can disable that window/error in the component configuration as in the image attached.
    emo
[SOLVED]Issue SEO stats with JsiteMap
Raymond Robert
thread linkthread link Re:Issue with JsiteMap
thread linkthread linkthread link Re:Issue with JsiteMap
Raymond Robert
thread linkthread linkthread linkthread link Re:Issue with JsiteMap
thread linkthread linkthread linkthread linkthread link Re:Issue with JsiteMap
Raymond Robert
thread linkthread linkthread linkthread linkthread linkthread link [SOLVED] Issue with JsiteMap
Raymond Robert
thread linkthread linkthread linkthread linkthread linkthread linkthread link Re:[SOLVED] Issue with JsiteMap
