Re:JSitemap Pro and EasyBlog (1 viewing)
TOPIC: Re:JSitemap Pro and EasyBlog
#452
Henning Deiters
JSitemap Pro and EasyBlog Karma: 0
in my sitemap is an url that should not be inside ("duplicate content" and layout issues): www.domain.de/easyblog
In my menu (and data source) is the url www.domain.de/blog - it is also in the sitemap.
How could I remove this?
Thanks and regards
#453
Re:JSitemap Pro and EasyBlog Karma: 84
Hi Henning,
i think you mean wrong url: www.domain.de/easyblog
and right url from menu: www.domain.de/blog
If i'm right, try to check by what data source is generated the url: www.domain.de/easyblog
There are different approach to exclude urls, for example for data source of type 'contents' you can exclude using categories or single articles, for menu you can exclude using the menu item. For user defained data source a custom filter could be required, based on how the component work.
#454
Henning Deiters
Re:JSitemap Pro and EasyBlog Karma: 0
thanks for the quick reply!
I have found an entry in my home menu with the easyblog alias. Maybe it is an autogenerated entry of EasyBlog? Anyway...
Thanks and regards,
Henning
#455
Yes as far as i know it's created automatically when you install EasyBlog
