Re:put a public Menu-point of a hidden-menu in Sitemap (0 viewing)
TOPIC: Re:put a public Menu-point of a hidden-menu in Sitemap
#4556
Markus Krauß
Re:put a public Menu-point of a hidden-menu in Sitemap Karma: 0
when i do this every not published menu is shown but i dont want every unpublished menupoint in sitemap... do i have the possibility to exclude then the points i dont want in sitemap ??
They dont appear in dhe list of menu-points i could exclude ....
#4557
Re:put a public Menu-point of a hidden-menu in Sitemap Karma: 84
Look at the menu data source settings.
In the below part you have a dropdown to exclude every single menu item that you don't want in the sitemap. So you can exclude and include what you want.
#4558
Markus Krauß
The not published menu-points are in the sitemap but not in the list to exclude them...
there are only the menu-points which are published...
how can i get them in the list or exclude them manuell ??
#4559
No you can't do that, you are forcing Joomla to show what must not be showed.
Unpublished items must not be showed, all sub-childs will be excluded as soon as you unpublish the parent menu in the Joomla menu.
The only workaround is to create a new menu with alias items poiting to elements that you want to be included in the sitemap.
#4560
Markus Krauß
Could i not manual give a link at the site like https://www.haustechnik-hart.de/sanitaer.html into the sitemap ??
That the site is in sitemap but not in the menu ??
#4562
If you want to add links manually to the sitemap create a new menu only for this purpouse not visible on the site, then add items of type 'External URL' specifying links that you want included in the sitemap:
http://www.haustechnik-hart.de/link1.html http://www.haustechnik-hart.de/link2.html
