Sitemap Config panel is white and does not function (1 viewing)
TOPIC: Sitemap Config panel is white and does not function
#4606
Abraham Tol
Sitemap Config panel is white and does not function Karma: 0
I installed sitemap (3.9) on my site. When attempting to change parameters on Configuration the screen comes up white and does not show all the tabs.Any Clues?
#4607
Re:Sitemap Config panel is white and does not function Karma: 84
looks like a PHP fatal error, i hope you installed the correct package according to your Joomla version. Double check it, if that's correct enable the PHP error reporting or look into the server error log to identify the cause.
