Re:How to use JSitemap PRO with multilanguage website ( English / Arabic ) ? (1 viewing)
TOPIC: Re:How to use JSitemap PRO with multilanguage website ( English / Arabic ) ?
#4847
Ashraf Tayab
How to use JSitemap PRO with multilanguage website ( English / Arabic ) ? Karma: 0
I used JSitemap PRO for more then one year, everything going fine with JSitemap PRO and thank you for your work
Now I add Arabic language to website how to use JSitemap PRO with multilanguage website ( English / Arabic ), now I am using in localhost to understand how JSitemap work with multilanguage website ( English / Arabic ).
Thank you
#4848
Re:How to use JSitemap PRO with multilanguage website ( English / Arabic ) ? Karma: 84
Hi my friend,
it works exactly in the same way, only you have to submit 2 sitemaps one for English and another for Arabic.
In the control panel you find the dropdown with languages to switch it and change sitemap links accordingly.
You find more details in the PDF docs at the paragraph 'Multilanguage support'
J
#4849
Ashraf Tayab
Re:How to use JSitemap PRO with multilanguage website ( English / Arabic ) ? Karma: 0
Thank you for your replaying, let me finish testing in localhost then if I facing issue well contact with you
Thank you a lot
#4923
Ashraf Tayab
I would like to thank you for this great extensions.
Every thing going good, I get full site map for ( en / ar ).
I use drop down with languages to switch it and change sitemap links accordingly.
One question please, about how to add multi language website to Search Console ?
My steps are :
1 : I added this code to .htaccess to redairect all link to non www
RewriteCond %{HTTP_HOST} www.gpsmapping.ly
RewriteRule (.*) http://gpsmapping.ly/$1 [R=301,L]
2 : I create property in Google Analytics for my website
Default URL : http://gpsmapping.ly
3 : Adjust Search Console
Add web property to Google Analytics
Now I had confuse how to add link for my website, the link it well be like this without ( www ) as it say in help file I should add separated link for every language : http://gpsmapping.ly/en/ http://gpsmapping.ly/ar/
When I get HTML file from Search Console to verify my website and I upload the file in root folder and I click verify it does not work because the file is not in ( http://gpsmapping.ly/en/ ) root as well as ( http://gpsmapping.ly/ar/ ), in root folder there is not folder ( /en ) and ( /ar ) in joomla root.
How could I fix this and add web property to Google Analytics ?
Thank you
#4924
Hi mate,
no you are off road.
Despite the fact that you have multiple language your site is still only one: http://gpsmapping.ly
The language prefix in URLs is only part of Joomla URL building, nothing to do with having multiple websites and doesn't affect at all Google Analytics and Search Console.
You will continue to deal with the same unique and real website http://gpsmapping.ly and nothing changes or must be added to the Search Console.
There are not real folder ( /en ) and ( /ar ) but it's only the Joomla router that manages the language string.
#4925
Ashraf Tayab
I was going in wrong way
I dell as the one website http://gpsmapping.ly
Only change is when I add sitemap, I add XML in Search Console for ( en / ar ) like this :
Sitemap: -------------------------------------------------=xml&lang=en
Sitemap: -------------------------------------------------=images&lang=en
Sitemap: -------------------------------------------------=gnews&lang=en
Sitemap: -------------------------------------------------=mobile&lang=en
Sitemap: -------------------------------------------------=videos&lang=en
Sitemap: -------------------------------------------------=hreflang&lang=en
Sitemap: -------------------------------------------------=xml&lang=ar
Sitemap: -------------------------------------------------=images&lang=ar
Sitemap: -------------------------------------------------=gnews&lang=ar
Sitemap: -------------------------------------------------=mobile&lang=ar
Sitemap: -------------------------------------------------=videos&lang=ar
Is the writ
Thank you
