Re:Sitemap links analyzer error (1 viewing)
TOPIC: Re:Sitemap links analyzer error
#4900
Gala Azul / YACHT TEMPLE S.L.U.
Sitemap links analyzer error Karma: 0
I have two languages.
When run sitemap links analyzer in one language its runs ok, but in the another language appear the following message:
Error
Page not found
No links found on this page
Any ideas?
Very thanks!!
#4901
Re:Sitemap links analyzer error Karma: 84
difficult to understand what could be the problem without checking the Joomla configuation on your website.
Try a couple of things:
1. Check if the Joomla language system plugin is enabled
2. In the component config try to change the option 'Links Analyzer working mode' => 'Compat'
3. Clear all the Joomla cache
4. Ensure to have the latest version of JSitemap installed too
John D.
#4902
Re:Sitemap links analyzer error Karma: 0
I'm sorry I was so short on explaining the problem.
Joomla version 3.51
JSitemap version 3.9
Plugin language enabled
Clear cache its ok.
Now it works fine with the "compat mode"
Thank you very much for the quick answer.
Now, that's the difference between "compat mode" and "standard mode"
#4903
Ok, that's good.
The compat mode skips some routing operations that could cause issues with certain third party components.
#4904
Ok John,
Very very thanks
Solved problem!!!!
