Re:create sitemap with joomla smart finder db? (1 viewing)
TOPIC: Re:create sitemap with joomla smart finder db?
#4939
Re:create sitemap with joomla smart finder db? Karma: 84
there is already a JSitemap plugin to integrate with jomholiday component.
Look at the download area for JSitemap, under the folder 'Data sources plugins for third-party apps' and you will find the JomHoliday plugin.
Take care that it's a JSitemap data source plugin and NOT a Joomla plugin, so install it in JSitemap as a plugin data source through the wizard, follow PDF docs if needed.
