SQL Injection detected in VM plugin (1 viewing)
TOPIC: SQL Injection detected in VM plugin
#4940
Slava TH
SQL Injection detected in VM plugin Karma: 0
Joomla 1.5 + VM 1.1
JSitemap PRO 2.0.3
trying to show products in shop, add "VM1 Products" as source.
Trying to change any field and save - get the 500 error "SQL injection detected"
How do avoid it?
#4941
Re:SQL Injection detected in VM plugin Karma: 84
You have probably a system plugin installed (maybe RS Firewall or Marco's SQL injection) that when saving the data source detect the SQL string used for the configuration query.
Add an exception to that plugin or unpublish it BEFORE saving the data source.
#4942
Slava TH
Re:SQL Injection detected in VM plugin Karma: 0
No such plugins are installed. Checked them all. Only have sh404sef built-in security, but it switched off for a long time.
#4943
As far as I know this is a feature of rs firewall,sh404sef is unrelated.
But if you have not security plugins installed in Joomla contact the hosting provider maybe you have firewall installed on the server.
#4949
Slava TH
Found the reason. It was EasyCalcCheck plugin.
