Re:Jsitemap Precaching Cron (1 viewing)
TOPIC: Re:Jsitemap Precaching Cron
#4976
Timothy cybersalt Davis
Jsitemap Precaching Cron Karma: 0
Is there a cron function for triggering a "re-precaching by ajax" and therefore cached site map?
I have a site with 16,000 pages and the precaching works awesome - but I'd like to skip having to manually regenerate the site map (plus stop forgetting to regenerate it )
Tim
#4977
Re:Jsitemap Precaching Cron Karma: 84
Hi Tim,
a cron can't trigger the precaching function because it's a javascript application and works in the Joomla backend.
By the way if you have 16.000 pages you should not need the precaching, the normal caching should be enough.
