Re:Difference in behavior for the www and non www domain. (1 viewing)
TOPIC: Re:Difference in behavior for the www and non www domain.
#4994
Kattenpension Shakira
Difference in behavior for the www and non www domain. Karma: 0
Hi
I've filled in SEO meta data in JSitemap Pro. However for some reason there is a difference in behavior for the www and non www domain.
Try www.kattenpension-shakira.nl and the page title is only Home
Try kattenpension-shakira.nl and the page title is Kattenpension Shakira Drenthe | Kattenhotel Dierenpension
The non www version shows the SEO meta data entered in JSitemap, however the www version doesn't
The same happens in the JSitemap administrator backend, www version does not show the SEO entries
I have no clue what is causing this or how to change this, can you please help with this?
Jan
#4995
Re:Difference in behavior for the www and non www domain. Karma: 84
Hi
this is how it works and it's expected.
Refer to this forum thread please: http://storejextensions.org/forum/view/10-jsitemap/4639-re-solved-search-engine-metainfo-disappeared.html
Metainfo are associated to unique links.
If you want to mantain your website with double domain (not recommended for SEO) you can export metainfo changing links in the CSV file from one domain to the other and then import.
#4996
Re:Difference in behavior for the www and non www domain. Karma: 0
Ah that makes sense....
Thanks for the quick reply!
