Re:Automatig assignation of Open graph tags (1 viewing)
TOPIC: Re:Automatig assignation of Open graph tags
#5074
Fernando Pieschacon
Automatig assignation of Open graph tags Karma: 0
Is there any way to assign automatically the "Full article image" selected in article's "Images and links" tab to the og:image tag? or the meta description entered in the article to og:description ?
The administrator shouldn't have to do it manually each time a publisher adds an article.
Thankyou.
#5075
Re:Automatig assignation of Open graph tags Karma: 84
Hi, the meta info panel works as an override, so you don't have to enter all of them but only that ones you want to override. Auto populate them is not possible because by default Joomla renders description based on multiple overrides. Refer to the FAQ http://storejextensions.org/faq/opening-the-search-engines-metainfo-dashboard-it-s-empty-why.html
#5077
publicvoid - Alexander Heinrich
Re:Automatig assignation of Open graph tags Karma: 0
I am just getting meta name="og:image" and not the meta property="og:image" as a result which causes confusion with facebook. Any recommendations?
#5078
That's known, it happens because of the document renderer of Joomla itself, tags are added as meta name and not meta property. However the final effect for Facebook is the same even it's reported in the Facebook debugger so it's not a problem.
