Jsitemap Pro Data Sources (1 viewing)
TOPIC: Jsitemap Pro Data Sources
#5132
Sightflow
Jsitemap Pro Data Sources Karma: 0
I've got Jsitemap pro installed but cannot create a image or video sitemap (it is blank)
My data sources are just the default Main Menu and Content. What do I need to do to generate the sitemap for images and video?
I've looked at the getting started video but it doesn't help.
My website is www.sightflow.com.au
Many thanks
#5134
Re:Jsitemap Pro Data Sources Karma: 84
the first problem is that you are using sh404sef and it must be configured correctly otherwise sitemaps are not ok.
Refer to this FAQ http://storejextensions.org/faq/can-jsitemap-work-with-sh404sef.html
or the PDF document downloadable from the purchased products area.
After that if the images sitemap is still empty the problem could be server related, the crawler for images and videos sitemap could be blocked.
In more details try to open the Links Analyzer and check if links are reported as 200 OK HTTP status code, if not ir means that the crawler is blocked. More info at this FAQ: http://storejextensions.org/faq/my-images-sitemap-doesn-t-embed-all-images-in-my-site-what-could-be-the-problem.html
