Re:After installing my server was too busy (1 viewing)
TOPIC: Re:After installing my server was too busy
#514
rougg
Re:After installing my server was too busy Karma: 0
see attched image...
if I clicked the icon for robot.txt.. do I still need the xml to my root?
#515
rougg
#516
Re:After installing my server was too busy Karma: 84
No,
exporting and placing a static sitemap.xml file at server root is an old solution also not easy manageable because sitemap have to be refreshed manually. This is done only in very particular cases, such as very large splitted sitemaps.
Adding the sitemap entry to robots.txt has the same effect, it indicates to every search engines where your sitemap is located, and offers a lot of advantages being sitemap managed automatically
#517
rougg
Okay thank you for clarifying things.
Consider this solved for now. I will monitor the server and see what caused the resources to go up.
Have a nice day!
