Re:Data sources empty (1 viewing)
TOPIC: Re:Data sources empty
#5161
Irez Enterprise
Data sources empty Karma: 0
Under the Data sources header I dont see any at all. it's totally empty. A sitemap is still being generated. I just have no way of editing any. I added 1 (twice) via the wizard and it shows up fine.
site: irez.cc
#5162
Re:Data sources empty Karma: 84
Can you please explain in more details with screenshots, etc what's exactly the problem and what you mean 'totally empty'?
Otherwise i can't understand the problem.
#5163
Irez Enterprise
Re:Data sources empty Karma: 0
as in there is no data sources, even though I have added some. https://irez.cc/index.php?option=com_jmap&view=sitemap
as you can see the map is being populated, but per attached there are no sources showing in the list
#5164
