Re:JSitemap Pro 2.0.2 on Joomla 3.6 (1 viewing)
TOPIC: Re:JSitemap Pro 2.0.2 on Joomla 3.6
#5342
Dino
JSitemap Pro 2.0.2 on Joomla 3.6 Karma: 0
Dear Team, I was wondering if JSitemap Pro 2.0.2 works on Joomla 3.6. Cannot find any info about this.
I could update to 4.1 but I am not sure if this would still work with my sitemap overwrite...
All best,
D.
#5343
Re:JSitemap Pro 2.0.2 on Joomla 3.6 Karma: 84
Dear Dino,
version 2.0.2 is a prehistoric version of JSitemap, although it still works on Joomla 3.6 i strongly recommend you to update to the latest 4.1
If you applied some custom overrides consider to refresh them to the latest version.
All best,
J.
#5344
Dino
Re:JSitemap Pro 2.0.2 on Joomla 3.6 Karma: 0
Thanks for the quick reply, will try adjusting the sitemap overwrite then!
Take care
