images sitemap throws error on line 381 at column 114: Entity 'aacute' not defined (1 viewing)
TOPIC: images sitemap throws error on line 381 at column 114: Entity 'aacute' not defined
#5346
biguphosting
images sitemap throws error on line 381 at column 114: Entity 'aacute' not defined Karma: 0
http://metrolibre.com/sitemap/images
Hello!
How can I fix this error?
Error on line 381 at column 114: Entity 'aacute' not defined
#5347
Re:images sitemap throws error on line 381 at column 114: Entity 'aacute' not defined Karma: 84
Hello again,
it means that there is an invalid character that is not accepted in the XML.
If the issue persists, locate the wrong character and exclude the corresponding image. As of now i don't get the error anymore.
#5349
biguphosting
Re:images sitemap throws error on line 381 at column 114: Entity 'aacute' not defined Karma: 0
I fixed it!
I had to revisit the data sources.
I went into content and then main menu and gave same priority to categories.
