Problems updating JStimapPro 4.2 to Joomla 3.6.2 (1 viewing)
TOPIC: Problems updating JStimapPro 4.2 to Joomla 3.6.2
#5429
Mayday Graphic Products
Problems updating JStimapPro 4.2 to Joomla 3.6.2 Karma: 0
Updated Joomla to 3.6.2 now get a blank screen when loading JSMP 4.1
Tried installing JSMP 4.2, nothing happens, just keeps trying to install
http://awesomescreenshot.com/0d162r5z00
Phil
#5430
Re:Problems updating JStimapPro 4.2 to Joomla 3.6.2 Karma: 84
Hi Phil,
it looks you have issue uploading the zip package or with the Joomla installer.
Try to use the built in auto updater, see here for more informations: http://storejextensions.org/faq/how-can-i-update-the-component.html
#5431
Re:Problems updating JStimapPro 4.2 to Joomla 3.6.2 Karma: 0
As I said Jogn JSMP does not load the backend, just a blank screen since updating to Joomla 3.6.2
So how can I use the Auto updater?
Phil
#5432
Mmmm in such case you have to upload the ZIP package through the Joomla installer.
If the package is not able to be uploaded, try to use the install from folder method uploading and unpacking it by FTP.
#5433
For Auto updater do you mean Joomla Updater?
On another MS site there was an update for JSMP, but there was an error - Invalid extension update!
http://awesomescreenshot.com/07c62rdr42
Phil
#5434
No the Joomla Updater is still not usable, it has been integrated starting from version 4.2 and later using the proper license email validation.
Now the only method you can have to update is using the regular Joomla installer as always been till now.
