Re:Search engine meta info lost Jsitemap-pro (1 viewing)
TOPIC: Re:Search engine meta info lost Jsitemap-pro
#5458
Re:Search engine meta info lost Jsitemap-pro Karma: 84
Hi Peter,
Data are never lost once saved to the Joomla database.
Please refer to this duplicated forum thread already solved to check if you have the same situation: http://storejextensions.org/forum/view/10-jsitemap/4372-solved-search-engine-metainfo-disappeared.html
I don't know what else you could have done wrong. By the way as a best practice always export them when finished.
Greetings
