images title in image site map does not work (1 viewing)
TOPIC: images title in image site map does not work
#5496
Marcin Niedobecki
images title in image site map does not work Karma: 0
hi,
my image sitemap generates list of all images from articles correctly but there is no title or image description in map even if all images in my articles contains alt and title tags. When I activate the option "Include only images with description" produces empty site map.
How to get image title to be generated into sitemap?
thanks in advance
Martin
#5497
Re:images title in image site map does not work Karma: 84
there is not on how to way, it works or not works.
It must works as usual, if not try to determine what could be different in your tags so that the title or alt attributes are not accepted when crawled.
The correct format is like this
<img src="/images/jsitemap_pro.png" alt="Blue Flower" />
or
<img src="/images/jsitemap_pro.png" title="Blue Flower" />
Settings should be 'Auto mode title/alt'
#5498
Marcin Niedobecki
Re:images title in image site map does not work Karma: 0
hi John,
all my img tags in all articles are correct, (other tools or plugins recognize them correctly) see example:
<img class="article-img" itemprop="image" title="sernik trójczekoladowy" src="/images/content/118/sernik_trojczekoladowy.jpg" alt="sernik trójczekoladowy" height="300" width="450">
Settings is set to 'Auto mode title/alt'
Marcin
#5499
The tag is correct, testing it the description of the image is included, see screenshot. So there must be something wrong on your website.
Post there the link to your page, i will check if you have broken or compressed HTML.
#5501
Marcin Niedobecki
My website is www.domowe-wypieki.pl
If you want I can send you admin access to this site via email.
Thanks in advance
Marcin
#5503
