Re:Incorrect sitemap for JoomShopping items (2 viewing)
TOPIC: Re:Incorrect sitemap for JoomShopping items
#550
NorrBits
Incorrect sitemap for JoomShopping items Karma: 0
I've installed component and decided to build sitemap. http://www.inferno-records.net/sitemap.html
There are no items at all except top menu.
There should be bunch of news (K2 component) and estore items (JoomShopping).
I've examined settings and installed two JoomShopping plugins in Wizard Data Source. As a result I got tree of catalogue items, but with wrong URLs, i.e. http://www.inferno-records.net/component/jshopping/cds/abigail-jap-sign-of-evil-ita-reaper-s-night-cd.html
the correct URL should be: http://www.inferno-records.net/mailorder/cds/abigail-jap-sign-of-evil-ita-reaper-s-night-cd.html
I suppose there is something wrong with configuration of the component since I there are no weblinks and K2 items too...
Please, help.
Joomla 3.3.3
JSitemap 2.3.2
JoomShopping 4.4.2
#551
Re:Incorrect sitemap for JoomShopping items Karma: 84
every data source created determine the exact elements and extensions included in the sitemap, this is the base concept of JSitemap that allows integration with a lot of extensions.
To add K2 items to sitemap you need to use the wizard buttons to add data sources.
About the Joomshopping it's should be enough enabling the auto SEF alias mode to route the raw 'component/jshopping' to the menu alias used by Joomla. This is well explained in the component documentation and settings description.
best regards
