Re:Priorities and Exclusions are not updated on XML (1 viewing)
TOPIC: Re:Priorities and Exclusions are not updated on XML
#572
Luis Pinto
Re:Priorities and Exclusions are not updated on XML Karma: 0
I've solved the priority issue.
There another one: My sitemap has over 10000 entries (articles).
When I've submitted it to Google Webmasters, it indexed almost all. Perfect.
The problem was that in the next day, it went from 9980 to 70 or 80 entries.
It could be a matter of double indexing, but I've tried to search for a couple of articles in Google search, and they didn't appear to be indexed.
Now, I've tried to export the sitemap into four files to see if it could be a problem of sitemap time processing.
Have you got any tips for me?
Thank you,
Londinium
#573
Re:Priorities and Exclusions are not updated on XML Karma: 84
That's very weird, Google should have valid reason to remove links from index.
First of all try to ensure that links are really not indexed, because GWT often reports inaccurate stats.
Try to do the search in Google site:www.mysite.com
You will be able to check the real site links added to Google index.
You can also check if a particular link is indexed using the exact link
site:www.mysite.com/article.html
Of course i assume that there are no robots.txt rules or htaccess blocks for Google bots.
