Re:Priorities and Exclusions are not updated on XML (1 viewing)
TOPIC: Re:Priorities and Exclusions are not updated on XML
#556
Luis Pinto
Priorities and Exclusions are not updated on XML Karma: 0
Hi everyone,
In my Pro JSitemap version, the priority levels and menu exclusions are not being updated in the XML sitemap.
All I get is 0.5 priorities for all menus and articles, despite having assigned different levels.
What have I missed?
Thank you for your time,
Londinium
#557
Re:Priorities and Exclusions are not updated on XML Karma: 84
Hi Luis.
could it be the case that the XML sitemap is cached?
If it's generated in realtime all the changes have to reflect on next generation immediately,
both for exclusions, priorities, etc
Cheers
#558
Luis Pinto
Re:Priorities and Exclusions are not updated on XML Karma: 0
Thanks for the reply.
No, I am not using Cache.
I've allowed several days to refresh, but changes never take place.
Thank you,
Londinium
#559
#570
Luis Pinto
I still can't do it.
By the way: is it possible to get the sitemap sorting the entries by date of publication?
The XML file seems to sort the entries in a completely random order.
Thank you for your time.
Londinium
#571
Hi Luis,
i think you refer to entries for articles... isn't it? (i mean data source 'content' )
If so the order is by default by categories and by Joomla ordering for articles, it's required for HTML sitemap but for the XMl sitemap the ordering of entries is completely not relevant.
Still curious about the priorities you can't change
