XML sitemap display (1 viewing)
TOPIC: XML sitemap display
#5581
Wightsynergy
XML sitemap display Karma: 0
Hi
My sitemap displays as - http://nimb.ws/A5sxVC
Can you please advsie?
Tank you
Iain
#5582
Re:XML sitemap display Karma: 84
#5583
Wightsynergy
Re:XML sitemap display Karma: 0
Thank you for your reply
I am using url - https://wightshops.com/index.php?option=com_jmap&view=sitemap&format=xml
But it changes to https://wightshops.com/component/jmap/sitemap/xml
I have added the text link in a standard Joomla content page and add url link http://nimb.ws/d2xz7y
Confused as to why the url changes
Any help much appreciated
Iain
#5584
You have confused me too
Normally you should use a footer menu and link with a menu item the HTML sitemap not the XML sitemap... what you are doing is a bit weird.
The footer should have this link:
to show an end user sitemap tree.
XML is only for search engines.
#5585
Wightsynergy
Wow, Thank you
I have completed a number of joomla websites and learnt, from reading forums etc that I should submit a xml sitemap to search engines
I thus presumed that it should be the same sitemap placed on the site so that when the search engine crawled the site it would find the same sitemap and regsiter any changes/updates in the sitemap
Are you saying that I should submit the xml to search engines and then an html on the site itself
Any teachings you may have on sitemaps, their functions and useage, would be much appreciated as it seems I have been doing it all wrong for ages.
Iain
#5586
Oh yes Iain. XML for search engines, HTML for website visitors.
You find some useful video tutorials here: https://www.youtube.com/playlist?list=PL6t5xIMeFJ2JG3OQASXPLi5YrFduVGWq3
regards
