Re:SEO Spider not updating (1 viewing)
TOPIC: Re:SEO Spider not updating
#5616
Wightsynergy
[CLOSED]SEO Spider not updating Karma: 0
Hi
I have been using the JSitemap PRO - Search engines metainfo dashboard to update the title description etc
I have saved each row and if I return to control panel then return to JSitemap PRO - Search engines metainfo dashboard the data has saved
But
When I then run 'JSitemap PRO - SEO Spider'
The results still display the data from before I made the edits in Search engines metainfo dashboard
Can you please advise me on what I am doing wrong, Or what I need to do so that the SEO Spider updates to reflect the changes I have made.
Iain
#5617
Re:SEO Spider not updating Karma: 84
Hi
I guess that you have some caching enabled, i don't find any other possible reason.
I suggest to clear all possible Joomla and server cache after editing.
Obviously ensure that links match exactly, if you have for example http://www.mydomain.com/link.html and http://mydomain.com/link.html, title/desc won't be the same.
#5621
Wightsynergy
Re:SEO Spider not updating Karma: 0
Hi John
I have checked that url's are the same
I will check caching and see what happens
Thanks again for support - New user so I will most likely be having a few questions but it will soon be over
Iain
#5623
Wightsynergy
Hi again
Ok, tried deleting all cache and now disabled page cache plugin and site cache disabled
Line entry saved.
here is screenshot of seo dashboard - http://nimb.ws/hnvbBw
Here is link to No1 entry - https://wightshops.com/component/jbusinessdirectory/visual-impact?Itemid=101
And here is page source - Still shows old data -
view-source:https://wightshops.com/component/jbusinessdirectory/visual-impact?Itemid=101
Still shows old data in seo spider - http://nimb.ws/1EXQ6S
Any hel;p much appreciated as ever
Iain
#5625
#5627
Wightsynergy
Doh
Just sent message for admin login to the contact on the website
Your request has been sent to our customer account manager
Shall I also send to your email, I missed this when sending the message or will you get the message I sent from the contact page?
Iain
