Re:Meta tag not working on minitek wall pro (1 viewing)
TOPIC: Re:Meta tag not working on minitek wall pro
#5655
Tenytranslations srls
Meta tag not working on minitek wall pro Karma: 0
Hi
I have some problem with url like this
http://www.hotelcitypc.it/component/content/article/92-offerte/62-mercato-dei-vini-dei-vignaioli-indipendenti?Itemid=993
generated by minitek wall pro, I can see it in the meta tag edit into jsitemap, but my custom meta are ignored.
Meta works perfectly on all other pages.
Can you help me on this
thanks
marco
#5656
Re:Meta tag not working on minitek wall pro Karma: 84
the URL reported is wrong, it's not properly routed to any Joomla menu item so you have issue even with meta tags.
You have to properly set a menu item routing to the article 62-mercato-dei-vini-dei-vignaioli-indipendenti to have replaced the part '/component/content' with the menu alias and to have removed the part '?Itemid=993'
Probably you are missing a menu item linking that category of articles or articles itself.
#5657
Re:Meta tag not working on minitek wall pro Karma: 0
You 're right
Thanks for your quick reply!
Marco
