[SOLVED]Re:jsitemap 4.2 doesn't work with zoolingual (1 viewing)
TOPIC: [SOLVED]Re:jsitemap 4.2 doesn't work with zoolingual
#5723
mika
[SOLVED]jsitemap 4.2 doesn't work with zoolingual Karma: 0
i have install jsitempa pro + zoo plugin and enabled zoolingual support
the default language sitemap works perfectly but the second language sitemap have both url from both languaeg
#5737
Re:jsitemap 4.2 doesn't work with zoolingual Karma: 84
#5746
mika
Re:jsitemap 4.2 doesn't work with zoolingual Karma: 0
Hi
I payed for the lastest version jsitemap pro + zoo plugin which support zoolingual
If you remember i proposed the idea for such option. and i know zoo and zoolingual better than anyone because of 3 years experiment . and now i am telling you this option doesn't work for other language .
there should be 2 strategy to determine correct url for every language
Sterategy 1- the one who using zoolingual ( this is my case) no need the menu language assignment . in fact every item have multi urls. every url for every lanuage, so having different menu linked to the category / categories of that item is not logical.
currently jsitemap does the job perfectly for default language sitemap, but in the other language sitemap we have both url of specific item. like this:
www.mysite.com/en/correct-language-url
www.mysite.com/en/default-language-url
* en is the second language
Sterategy 2- the one not using zoolingual and need to assign item's category to the menu with related language.!
in this case every item has created for a specific language, so every item's category has to addressed by a menu which has language assignment.
I really love jsitemap and appreciate for your effort.. jsitemap is the best sitemap extension and could be even better
#5747
#5765
mika
[SOLVED]Re:jsitemap 4.2 doesn't work with zoolingual Karma: 0
thank you for your attention
i found where the problem is!
i already had the default zoo item as data source .
you should mention it this plugin is a replacement for default zoo item comes with component. i uninstall it and the problem have been solved.
