Re:can index/follow be impacted from JSitemap Pro? (1 viewing)
TOPIC: Re:can index/follow be impacted from JSitemap Pro?
#5897
Re:can index/follow be impacted from JSitemap Pro? Karma: 84
only feature to rule that in JSitemap is included in the 'Search engines metainfo dashboard' -> column 'Indexing directive'
Check there if you have chosen 'Noindex, nofollow' by mistake for the home page.
If that's ok probably you have some other plugins managing the index directive.
