Re:Two problem sitemap and configuration (1 viewing)
TOPIC: Re:Two problem sitemap and configuration
#5948
Marcin R
Two problem sitemap and configuration Karma: 0
Hello.
1) In Google search a try add video sitemap google say:
"Sitemap appears to be an HTML page. Instead, use a supported Sitemap format."How to generate XML for video ?
2) Second problem a have configuration don't save change if i try push the button save or control panel nothing happend
#5949
Re:Two problem sitemap and configuration Karma: 84
Hello.
1)Use the link for videos sitemap and check that it's correct before submitting. You already talked about this link in the previous post https://mjmartino.eu/index.php?option=com_jmap&view=sitemap&format=videos
2)Check if the component is updated, if you updated recently clear the browser cache, use Chrome, other than that check if there are javascript errors in the Joomla backend
#5950
Marcin R
Re:Two problem sitemap and configuration Karma: 0
1) We discus about not all videos grab from content in previous post.
I try add this link and link from administrator nothing change.
2) I find error not loading
administrator/components/com_jmap/js/jquery.simplevalidation.js
But this problem Cloudflare ..
#5951
To ensure that the problem is not due to Google cache you should try to submit an random link to force refresh, example: https://mjmartino.eu/index.php?option=com_jmap&view=sitemap&format=videos&nocache=1234
If still same problem probably the problem is on the server, GoogleBot could be blocked. Maybe same issue of Cloudflare, Cloudflare caching or firewall, etc
#5952
Yes you have a problem on your server.
I tested your website on http://www.botsimulator.com/ and indeed there is an SSL error when accessing as GoogleBot
Must contact the hosting provider to fix.
#5953
Marcin R
Hmm okey I try block first Cloudflare if nothing change. Then check my server.
