Maintenance Help (2 viewing)
TOPIC: Maintenance Help
#6076
Alexandre Thrrien
Maintenance Help Karma: 0
Hi John, I've just update to version 4.2.2.
It seems that the component was down for a while since I didn't update it after updating joomla up to the version the component was not supported, without my knowledge. Does that mean the new links were not indexed or did google missed any new articles or K2 category that were added to my site?
It's been a while since I've checked and did maintenance on this site. It looks a bit messy.
I've noticed that many K2 links have an extra expression in the SEF, it looks like it could be duplicated canonical links. Would you have any suggestions?
Here is one example: http://www.quebecguitare.ca/suivi/simon-gag/content/guillaume-t-quebec
Would you have any guidelines or a tutorial on what to do maintenance on a website using Jsitemap?
I've just ran Analyzing Links function and it looks messy. I've got links indexed I didn't suspect and they are listed FIRST in the query. Does that mean google sees these links FIRST or it's just the component that renders the results a certain way?
What would you do in order to clean verify and clean a website using the full potential of JSitemap?
Do you have a flowchart?
Thank you
REgards
PS.: I've printed a link analysis result so you can see what I am dealing with.
P.S.S: The section "site metainfo" does it supports K2 items ?
Maintenance Help
Alexandre Thrrien
thread linkthread link Re:Maintenance Help
Alexandre Thrrien
