Re:K2 Falang and Jsitemap (1 viewing)
TOPIC: Re:K2 Falang and Jsitemap
#6121
daniele leonetti
K2 Falang and Jsitemap Karma: 0
Hi Guys,
I have purchased your Jsitemap PRO and work great, I have only a problem with K2 Item and falang translation.
Jsitemap not translate title name of the k2 Item in no-default language, you know a solution?
There is a way to pick the name of K2 Item in the right language?
Thanks for help.
#6123
Re:K2 Falang and Jsitemap Karma: 84
that's possible but you have to install the K2 datasource of type 'plugin' that supports the Falang multilanguage working mode instead that the default SQL one based.
You find it in the download area, a datasource of type 'plugin' is installed through the wizard (see image), you find more info in the PDF docs.
#6124
daniele leonetti
Re:K2 Falang and Jsitemap Karma: 0
Very good, this works perfectly thank you very much!
