301 Redirect Issue (1 viewing)
TOPIC: 301 Redirect Issue
#6187
MGSW Design Limited
301 Redirect Issue Karma: 0
Hi All,
I am in need of some help. I will try to explain to the best of my ability as I am not a technical person. To create SEO friendly URLs I’ve searched online for the following lines of code and implemented them in the Htaccess file. This worked and removed the index.php and redirected the URLs to SEO friendly URLs as well as redirected from non www to www.
However, this has created an issue in the jsitemap pro. The meta info for each URL have disappeared from the search engine metainfo dashboard and I cannot update the info. Is it because of the rewrite rule? How can this be solved?
RewriteCond %{HTTP_HOST} ^mamotcv.com [NC]
RewriteRule ^(.*)$ http://www.mamotcv.com/$1 [R=301,L]
RewriteCond %{REQUEST_URI} ^/index\.php/
RewriteRule ^index.php/(.*) /$1 [R=301,L]
RewriteCond %{REQUEST_URI} !^/administrator/
RewriteCond %{THE_REQUEST} ^.*/index\.php
RewriteRule ^(.*)index.php$ /$1 [R=301,L]
#6191
Re:301 Redirect Issue Karma: 84
refer to this FAQ for metainfo migration between different links: http://storejextensions.org/faq/i-changed-the-website-domain-how-may-i-avoid-to-lose-all-metainfo.html
If you have an issue to add new records because of the redirects rules in the htaccess, temporary disable them when editing the metainfo in backend.
