Re:Metainfo Dashboard Not Over Writing (1 viewing)
TOPIC: Re:Metainfo Dashboard Not Over Writing
#6216
Dxb Labs
Metainfo Dashboard Not Over Writing Karma: 0
Not sure what I need to change to get Metainfo Dashboard to work. Neither the Title or Description saved are shown when running SEO Spider.
Joomla 3.6.4
Jsitemap 4.3.1
Gale
#6217
Re:Metainfo Dashboard Not Over Writing Karma: 84
Not sure me too.
Normally it's straightforward. Just specify title/desc and save.
If links are exactly the same for the SEO spider it's immediately visible. If not the problem could be a cache that must be cleared/disabled. Also you can check it opening directly the page instead of the SEO spider.
