Re:Jsitemap - meta title and meta descriptions disappeared (1 viewing)
TOPIC: Re:Jsitemap - meta title and meta descriptions disappeared
#6241
Chris Baker
Re:Jsitemap - meta title and meta descriptions disappeared Karma: 0
Hi
Started using HTTPS and followed your suggestions.
Went to http site - search engines meatinfo and exported
changed all links to https
Went to https site - search engines metainfo and imported
Got a message saying import successful but all the boxes are still empty ?
Any suggestions?
#6242
Re:Jsitemap - meta title and meta descriptions disappeared Karma: 84
Hi
Probably there is a mistake somewhere so links didn't match when importing it.
Check carefully the domain and links.
#6243
Chris Baker
Not sure how there could be mistake?
exact form as exported just added "s" to http and imported
#6244
I don't know, the only required condition is that links in the csv are the same of the sitemap/metainfo and the csv has a correct format as the one exported. No import = no match between links.
Check if the error is not the mismatching of www/not-www in the domain and that you accessed the https backend accordingly before reimporting data.
#6245
Chris Baker
Problem solved thank John.
Seems csv flle was edited using excel and added invalid characters.
If it helps anyone this is explained in detail here https://storejextensions.org/faq/i-changed-the-website-domain-how-may-i-avoid-to-lose-all-metainfo.html
So use the right editor to edit your file
Great support thank you.
