Re:jsitemap pro, Analyze sitemap links (1 viewing)
TOPIC: Re:jsitemap pro, Analyze sitemap links
#6255
GEAR.it
jsitemap pro, Analyze sitemap links Karma: 0
Dear all,
everything works perfectly apart the sitemap link analysis.
When I start it the window with the progress bar opens.
It starts running with the green progress bar.
After a while the progress bar become red.
The window says:
"Sitemap is being generated and analyzed, please don't close the page until completion.
Open a new tab to continue navigation.
Error storing XML file in the analyzer cache folder,
please check permissions and try again"
com_jmap/cache as +xw permissions so it would be able to create new files and, if needed, folders.
Is there any other cache or temporary folder where jmap is writing in?
#6256
Re:jsitemap pro, Analyze sitemap links Karma: 84
Dear,
thanks so much.
The exact folder where the file is stored is located at the following path:
root\administrator\components\com_jmap\cache\analyzer
#6257
GEAR.it
Re:jsitemap pro, Analyze sitemap links Karma: 0
I know, all the com_jmap\cache inherit that +wx permission.
Any other suggestions?
#6258
No there is nothing else, when you start the process check that the file is written by FTP, otherwise it's a permissions issue.
