An admin user without super-user rights just clicked "update" on the JSiteMap control panel. Unfortunately the files were write-locked and the update failed with a warning saying there was a permission problem. However, the JSiteMap control panel now thinks that the latest software is installed, which is not the case.
Please can you fix the following?
- the update should NOT show for anyone without the correct rights to install software
- ACL needs to stop people without correct rights installing software. This is a security problem.
- If the update fails because it can't write files, the version number should not be incremented in the extensions table
It might be best to just use the standard Joomla update mechanism, which would solve these issues.
-David.
