Hi
First of all thanks for an excellent extension
Now I have a slight issue with data coming from SobiPro for a consultants directory. The name of the consultant is the entry title and for most of the entries it is fine, however, some have 'No Name' as the title.
Checking the SobiPro entry they all appear OK
Any thoughts??
Here is the link to the site map
https://www.rnohppu.com/ppu-site-map.html
and if you drill down into the second tab 'RNOH PPU Consultant Directory'
and then 'Consultants'
Scrolling down the list you will see the 'No Name' entries
Getting an answer would be cool as I'd like to submit this to the search engines
Many thanks
Stuart
