Problem with 404 (1 viewing)
TOPIC: Problem with 404
#690
Atlanta Internet Design
Problem with 404 Karma: 1
When I submitted my new sitemap to google for atlantainternetdesign.com I get the following message:
General HTTP error: 404 not found
HTTP Error: 404
How can I fix this?
thanks bob
#691
Re:Problem with 404 Karma: 84
Hi Bob,
ensure that link submitted is correct, i've just looked at your site opening the XML sitemap, but no problems or 404 are detected: http://atlantainternetdesign.com/index.php?option=com_jmap&view=sitemap&format=xml
The link you have to submit using GWT is:
#692
Re:Problem with 404 Karma: 1
Awesome--Thanks for the incredibly quick reply and fix--worked perfectly!!
bob
#693
No problem Bob
