Duplicate entries in SEO Dashboard and Spider (2 viewing)
TOPIC: Duplicate entries in SEO Dashboard and Spider
#7069
Steve Dingle
Duplicate entries in SEO Dashboard and Spider Karma: 0
Very new to JSitemap and sitemaps and seo in general.
I was using the 'search engines metainfo' option to update the titles and descriptions and everything worked fine as far as I know. There was a single entry for each of my pages, there aren't many about 25.
However, after I activated my htaccess, added sitemap to robots.tct and submitted my sitemap to google I can now see there are two entries for every page in both the SEO Spider and search engine metainfo pages.
Those entries look like exact duplicates. Is this expected behaviour?
The site seems to be working fine as is my and the HTML sitemap is only showing 1 entry for each page, https://www.rightwaydata.co.uk/index.php/site-map
Steve
#7070
Re:Duplicate entries in SEO Dashboard and Spider Karma: 84
i see a normal 1 entry in your sitemaps, all formats.
However the htaccess and robots,txt can't duplicate links in a sitemap so probably you experimented some other weird issue.
My recommendation is to activate htaccess and links rewriting to remove 'index.php' from Joomla links.
#7071
Steve Dingle
Re:Duplicate entries in SEO Dashboard and Spider Karma: 0
Thanks for the quick response. Being also ignorant about htaccess I had to do a little research but I changed the 'Use URL rewriting' to Yes and that does seem to have solved my problem, i.e. no more duplicates.
Thanks again,
Steve
