Hi JSitemap,
I have done some tests and it looks like that JSitemap doesn't show the Open Graph protocol a little bit different then other extensions where I don't have issues with showing images in Linkedin.
I think the prefix is missing like (prefix="og:
http://ogp.me/ns#"
and I miss the
meta property.
I only see the
meta name.
I hope you can help me to fix the issue why Linkedin is not showing the image and description.
I did the test with ITPMeta to see the difference in Open graph protocol on my production and acceptation environment.
Hope you will take a look at this issue because I see other people with the same issues. And it would be very nice if we only need Jsitemap instead of other extensions to get the OG protocol right for Linkedin.
Kind regards,
Lumiga
