Re:Why some images do not show up in an XML images sitemap? (1 viewing)
TOPIC: Re:Why some images do not show up in an XML images sitemap?
#7121
Amar Guillen
Re:Why some images do not show up in an XML images sitemap? Karma: 0
Thank you very much for your reply.
Would you give me the instruction for the cronjob? Or is there any tutorial about it?
I am using the website Webcron to backup my website everyday using Akeeka. So I have a such service.
Another question for you. When I add an article or when I modify something in my website, the caches are cleaned automatically using a plugin. Is it a problem with Jsitemap pro? Does the extension has its own cache or the general one?
Thanks for your help
Amar Guillen
#7122
Re:Why some images do not show up in an XML images sitemap? Karma: 84
Using the cronjob is really easy, it's just a link.
Refer to the PDF docs at the paragraph 'Cronjobs usage', notice that your server must have unlimited timeout for cronjob scripts otherwise this won't help and won't work.
The cache cleaning is not a problem, it has its own cache.
#7128
Amar Guillen
Thank you.
Everything is fine now.
You can close the ticket.
Thank you for your help. It was very clear and easy.
All my best
AMar
